In previous threads I've discussed creating a UOA database which will allow our community to organize *ALL* of the UOA data we have.
I've got the database format worked out, and I have an Excel spreadsheet that I use for initial data gathering.
I can use scripts to pull data from the Excel spreadsheet into my Access database without much manual intervention.
I'm happy to do all the work myself, but we have a very healthy collection of UOA, especially as our community has grown, plus my wife doesn't really understand me doing two hours of unpaid data entry every night...
I currently have our 51 oldest gasoline UOAs. Some of the labs from back then have changed formats...
I've also gathered 9 of our higher-mileage UOAs from various dates and every single Ford Duratec 30 analysis I could find, which was 22 of them.
I figure I can get this done months earlier if a couple of you guys volunteer to enter in a dozen or so UOA each into my spreadsheet every now and then, which I can then integrate into the database to share with the rest of the board.
If you'd like to get started, let me know, in thread, by PM or by emailing tomjones762003 [[[at]]] yahoo.com.
I can give you a time range for UOA to collect, and if you like I can even give you the URLs for the ones you'll be assigned.
My current format follows. Certain data was censored and certain fields abbreviated due to the fact that it would mess up the chart.
code:
Date 3/13/06 3/22/06
Lab Schaeff Dyson
***Vehicle ID***
Make Mercury Chevrolet
Model Sable Prism
Year 2002 2000
Engine 3.0 24V 1.8L 4-cyl (1ZZFE)
Miles on Vehicle 57454 108196
***Oil Identification***
Oil Brand Exxon Castrol
Oil Series Superfl German Syntec Lot M02xxx
Oil SAE J300 5W20 0W30
API SX SL SL
Miles on Oil 9848 4786
Months In Service 7 4
***Elements***
Antimony Sb NR NR
Cadmium Cd NR NR
Vanadium V NR NR
Aluminum Al 6 1
Chromium Cr 0 0
Iron Fe 23 6
Copper Cu 6 1
Lead Pb 1 1
Tin Sn NR 0
Molybdenum Mo 128 5
Nickel NR 0
Manganese Mn NR 1
Silver Ag NR 0
Titanium Ti NR 0
Potassium K NR 0
Boron B NR 1
Silicon Si 16 10
Sodium Na NR 1
Calcium Ca 1262 2959
Magnesium Mg 5 129
Phosporus P 498 715
Zinc Zn 619 860
Barium Ba NR 0
***Viscosity***
cST @ 100 C 7.02 11
SUS @ 210 F NR 62.7
***Misc***
Flashpoint (F) NR 375
Fuel % N 0.5
Antifreeze % 0 0
Water % 0 0
Insolubles % NR 0.2
Sulfur 7 NR
Oxidation 10 NR
Nitration 24 NR
TBN NR 3.2
Ferrous Debris NR NR
Fuel Soot % NR NR
Glycol NR NR
ISO Code NR 17/14
Additives LC NR
URL SNIPPED FOR DISPLAY PURPOSES
Notes SNIPPED FOR DISPLAY PURPOSES
Location Ohio Arizona
***Filters used***
Air Filter NR STP (has about 30K)
Oil Filter NR K&N HP-1003
***Particle Count***
>2 micron NR 2146
>5 micron NR 795
>10 micron NR 220
>15 micron NR 85
>25 micron NR 20
>50 micron NR 1
>100 micron NR 0
