The maximum BMEP or max torque is the lowest GPHPH or max eficency. BMEP=BRAKE MEN EFFECT PRESSURE AND GPHPH GALLONS PER HORSE POWER PER HOUR. Ed
No, although maximum BMEP and minimum BSFC (max efficiency) sometimes come at about the same speed-load combination.
You meant Brake Mean Effective Pressure, and Gallons per Horsepower-Hour (= gallons per hour per horsepower).
I use an OBDII data reader and monitor Load. This is in effect the calculated VE the engine is seeing. Airflow X rpm. With a turbo or SC this value will rise well over 100%.
