I have a JD LT155. How many bolts should I read across the battery terminals while running? Trying to make sure my mower is charging the battery.
If I’m not getting that then my stator is bad? I get the same voltage at the battery as I do at the regulator which is 12.5You should see at between 13.7 and 14.5 volts across the terminals when the engine is running.
Would that plug be under the blower shroud?It could be the stator which creates AC current that should be about 30 volts on most mowers. There should be a plug that you can disconnect to test it with your multi-meter. If it does put out 30v AC, then you know the problem is with rectifier/regulator somewhere.
With it unplugged running?If you found the regulator block with 3 pins, the center wire (usually red) leads to the battery, the two wires on the outside (usually white) lead to the stator. Unplugged from the regulator the stator should measure about 1 ohm between the stator wires, open circuit from either wire to ground, and with the engine running about 30 volts AC as mentioned.
Yes, unplugged running.With it unplugged running?
So attach the multimeter across the two white wires while running and it should read 30 volts?Yes, unplugged running.
They’re white, and the wires on the left get super hot. I also have continuity between each of the white wires to the red battery wire off the voltage regulatorI don't know what color the wires from the stator will be on your mower... can you trace them back up to where they would come out by the bottom of the flywheel?
