Volkswagen Air Cooled Engine Oil
Originally Posted By: weasley
Pretty much - ashless dispersant (AD) oils are used in certain air-cooled aviation engines to avoid ash build-up which can cause pre-ignition. These engines tend to use a little oil by design, hence wanting to avoid ash deposits.
They won't be "0%-SAPS" though, as the mineral base oil will contain sulphur.
What temperature would you need to "flash off" all the oil, leaving the ash ?
Well, that's a point of semantics. In reality the oil will combust with the fuel and leave behind any ashy deposits; a simple distillation will not create any ash (as you know!).
It doesn't help that people talk about ash content of an oil, which is wrong. It is ash propensity, because you need the combustion (oxidation) to form the ash from the metallic elements in the additives (stating this for all interested readers, not aimed specifically at Shannow).
