c_rossman
It takes 3 minutes for 10w30 oil to reach every part of an engine that has sat for 12 hours when it is 70 degree's out. Oils dont flow the same at the same temp, A cold engine always bypasses, if it didnt you would twist off the distributor shaft, It could be 100 degrees out and it will still bypass. Every oil pump has a different bypass setting, Some are 60psi and some are higher. My 460 the bypass is set at 80psi, that is why it never goes above that even when reved.
