Viscosity Determination
MolaKule
Staff member
Iowegia - USA
This question is not open to ANY Engineering Discipline or to Tribologists, so other members have an opportunity to answer the question.
In a machine system, the 40C viscosity for a lubricant can be determined by:
V40 = 7000/SQRT(VL), where VL is the "Pitch Line Velocity" in feet/minute.
Identify the machine system. [E.g., engine, hydraulic, gear, etc.]
Omissions of seemingly necessary factors makes that equation interesting---and hints at the purpose of the machine!
Any Googling: "Pitch Line Velocity" should be able to find the answer.
Originally Posted By: 1JZ_E46
Gears, such as in a manual transmission?
You've got it!
As seen here,
Spur Gear Design
Pitch Line Velocity is a factor in the design of Gear Trains, so the system would be Gear Systems.
So 1JZ_E46 wins the coveted virtual BITOG Cup with a virtual quart of low NOACK, FUll Synthetic oil!
