quote:
This is the viscosity chart in my owners manual.
5W30 or 5W20 -22F(-30c) to 18F (-10C)
10w30 or 10w40 0F(-20c) to 60F(15c)
15w50 or 15w40 4F(-17c) to 95F (34c)
20w50 or 20w40 15F(-10c) to 95F (34c)
Toronto's temp is around 15c to 35c during summer and -20c to +5 during winter season.
Based on these numbers which AMSOIL is best for daily driving?
It seems even 10W40 is not good enough for summer days!!
You failed to supply some critical information. Not sure how everyone is quick to tell you what oil to use if they don't know the exact application? What model year is that Jetta, and what engine does it have?
![[I dont know]](/forums/graemlins/dunno.gif)
I assume it's a new car, since I haven't seen a 5W-20 listed in a VW manual until now. That engine may not require an A3 oil, in fact I doubt it, because 5W-20 can't even meet A3 requirements!
That said, and A3 oil will not hurt the engine, but you may not want to extend the service interval to whatever VW recommends for this car, if you use an A3 rated oil. What's the suggested OCI?
Also, the oils you posted must have been listed in the mineral oil section of your oil chart, as evidenced by the upper ambient temp limits. These temp limits do not apply to synthetic oil. All 0W-30/40, 5W-40, 10W-40, etc synthetic oils will be fine at ambient temps above 40 degr C.
You'd be best advised to check the synthetic oil section of your oil chart (Usually far left column). You will most likely find 0W-30 and 0W-40 listed, and I would think that those would be your best option, especially if you end up changing your oil in your climate only once a year. 35 degr C ambient isn't exactly blistering heat, but -20 is quite low, so I'd prefer a 0W-30/40 over a 5W-40 in this case.
PS: VW will hardly put outdated oil charts in their manuals. However, like most other makers, they are dumbing down everything, making their suggestions increasingly incomprehensible and non-sensical, should one dare to think on his own.
[ June 02, 2004, 06:22 PM: Message edited by: moribundman ]
