VIRGIN PUROLATOR P1 PL-24457 CUT OPEN
In the shop
Good Afternoon BITOGERS. 🇺🇸🇨🇦🥃
As most of you saw in “post your latest oil purchase” thread in PCMO section I got this filter at AAP dirt cheap. No real use for it and no family or friends could use it.
*****, wavy pleats so I’m glad I sacrificed it for BITOG
you should look at this video on youtube and wait for the Mobil 1 filter, I believe it is made also by Purolator, I think you will find this interesting.
I would say theFL-400S but as bluefeb95? Said it has no bypass
Off the top of my head I believe size wise I think it's in between the FL910 and FL-400, but has no bypass, the fram equivalent is the PH3682, I think it's only applications were older Nissans and maybe some VW or Audi engines.
Adam that's what I'm running on the Corolla now only a 14476. That's the usual place for the pleats not to look good at the closing seam. I've been using them since just before 2010 with no tares. I only have one of those left its getting old and will like go on my next OCI this month. Likely will cut the current one later this month or maybe November if the sun doesn't start to cooperate.
