Been scanning the older posts and come across a great deal of debate on using the st. weights vs. multi visc. Some posts even declared that the Quicksilver 15w40 is a straight weight since there are no VI improvers. Why would they call it a 15w40 then?? But, where I need guidance is the diesel engine oil for a gas boat engine. Thought that was the way to go, but read some more that maybe it isn't because it could leave deposits within the engines. Are we comfortable that the Quicksilver has enough corrosion inhibitors that a diesel oil can't touch, even if it's CI/4 rated? I do believe that VI would get the living be-jesus squished out of them in a boat motor and maybe that's why they are not good, which would lead to other deposits.
I, just this year, went with the Pennz. straight wt. HD 40 for my 18 foot 3.0LX Merc. First weekend out, oil pressure held steady around 40 psi. This weekend, noticed it would drop to around 20 at idle after a run, but jump back up to 40-45 when running. Last year I used Valvoline's 20W-50, oil pressure would jump up to 60 psi and drop to 20 at idle. That made me a little nervous. BUT the Valvoline obviously had VI's in it, but pressure fluctuated by 30 to 40 psi. Wouldn't think that would happen to that kind of oil. What about the st. weight Pennz. 40, no VI's in it, it fluctuated too, granted, not as much? The little 3.0 works a lot harder than their bigger cousins, but oil pressure differences puzzle me. School of thought was the VI's would "adjust". But both kinds seem to indicate to me, that after some use, they ALL thin out, regardless of VI or not so don't waste your time and money trying to determine a correct multi visc. oil for a boat engine. I think even Bob uses straight weights on his boats, or knows lots that do. (all conditions were the same, speed, temp, amount of oil in engine, etc. etc.)
Also, switched to a 18 pitch 4 blade comprop. Unless you want quick planning and low top end, don't waste your money. But it will make your boat jump, I mean JUMP, out of the water. Would be my pick of props for pulling skiers and tubers.
[ June 10, 2003, 04:23 PM: Message edited by: Schmoe ]
