Venting the heat out of the top of my arched exposed breezeway?
Only a problem when the temp is pushing over 85°F, sun beating on the ~SW roof portion and air absolutely still. As soon as the earth rotates for trees to the west to block, then area temp drops off.
Just read this. You may have radiant heat problem and not hot air being trapped under there. If you say you have ridge vents already there, (I cannot see them from your pic), then that should vent any hot air anyways.
They are really skinny. Like less than 1/4" outlets
That looks really nice. Great build quality.
I don't know if there is a way to mitigate radiant heat from the sun, working it's way through the structure, other than build a ceiling with an air gap, then insulate and ventilate that space between the underside of the roof and the ceiling.
Do you have room for one of those electric thermostat/ humidistat controlled electric attic fans? (Humidity likely not an issue since it’s already open.)
In cold Canada or hot climates, air flow is everything. You need to have air flowing from the bottom edge of the roof to the ridge and out. Each space between rafters needs to have an intake vent. Quick picture I did to show air entering the U shape and exiting the roof vent.
The radiant heat issue is solved by insulating below the airflow with a false ceiling.
That is only for roofs that have an attic or space that's not open. This particular case it's all open, there is no need for anything at the bottom. And if the ridge vents run the entire length of the roof, that should be enough for any hot air to escape.
Since Pablo mentioned this space cools off rather quickly once the roof is in the shade, I believe this is radiant heat issue and not stagnant, hot air accumulating there.
Right, but I still think it's a combo of both. Inadequate roof venting with the huge heat load and radiant heat issue.
1. Ceiling fan
2. See if an upward blowing floor fan will do anything, like a large one.
3. Maybe wall mounted fans, one blowing upwards and another one pulling downwards.
The point is to get some type of circulation. You could also wear a doo rag filled with ice or maybe a beanie cap or hoodie. :LOL:
This looks like the stuff I used.
https://www.homedepot.com/p/GAF-Cob...d-Plastic-Roll-Ridge-Vent-2056000CU/329616002
It may just be the angle of your photo, but I don't see any airflow opening to the ridge vent created by cutting out ~3" of the roof sheathing on both sides of the center ridge board as shown at the 4 minute mark of the video below.
