Vavoline Race Oil VR-1 VV229 40W
The 4th sample is the Vavoline VIV Race oil. A case of this oil was given to me to try by Vavoline.
I always chuckle at the comments.
This is a 15:1 1000 + HP 565cid Methanol injected drag race engine. The runs are the actual full power passes down the drag strip. They are in addition to the hrs of warm up.
The lead is from the race gas I use in a 2nd fuel system to help warm up time. Run it for start and idle only.
The other 3 samples are Schaeffer's 40W Micron Moly
Questions.
1) The sodium they used as an additive. Can that also act as an oxidizer?
2)The TB at 7.1 is a tad higher then the Schaeffer's Micron Moly on the 3 other sample with about the same use. What additive seem to drive that TBM more than others? I see the VR-1 has stronger Calcium and a tad less P and Z, also a trace of silver as well as Sodium.
3)What is Nitration that got to 20 on this sample?
