A few days ago I stopped to get gas. When I started pumping the gas, the gas pump handle kept kicking off. I thought I might have had the nozzle in the tank neck too far so I pulled it back. Same thing. Luckily I had a half tank and was not empty. I didn't think anything about it until my dash lit up with a CEL. I called my sons boss (shop foreman at the Ford dealership) and told him what was going on. He told me that the VCVS was stuck in the closed position. It's located above the spare tire on the bottom of the bed. He said to remove it and blow into it. If air passes thru then it's fine. If air doesn't pass thru it, replace it. BUT, a temporary fix, until I can get a new one ($60 from RA + shipping), is to spray the plunger with throttle body cleaner and blow it out with air. So, this Friday, my truck goes up on my cousins lift and we operate.
Has anyone else had this problem before? This is a typical emission design on ALL gas engine makes of trucks and cars in America.
