Personally, I haven't been very impressed with the valvoline AC and synthetic oils. The durablend and maxlife seem to do fine, but the synthetic is an overpriced, weak oil.
How do you figure?quote:
but the synthetic is an overpriced, weak oil. [/QB]
Look at the 10w30 Synpower:quote:
Do you have the same numbers for other leading Synthetics? I don't believe Maxlife and Durablend is better than SynPower. Maxlife scored a 500 on that link I posted up at the top.quote:
Flash Point: 250C (482F)
NOACK: 8
Pour Point: -42C
Those are pretty good numbers. But I agree that probably the best of Valvoline is Durablend and Maxlife.
I don't have numbers for other synthetics. I know the Citgo synthetic oil beats Synpower on cold crank and cold pumping.quote:
Wrong is not = goodquote:
Originally posted by gmayer5454375:
The link you supplied about the motor oil rankings is a good information source,.
I bought some at $2.69quote:
Originally posted by lobo11:
The claim is NAPA synthetic is Valvoline Snythetic.
I am in the process of ordering 7 cases of Royal Purple, so the only facts I can give you is I have some free SynPower in the garage, and I won't use it. Giving it to my SIL. Which is better? For my money, no question.quote:
Last bump...
Anybody have more SynPower information? How about SynPower vs RP oil, which is better? (Based on facts, of course...)
Is it your opinion that RP is better, or fact? If I do change from SynPower to RP, which RP do you recommend. RP 10w30, or RP Racing 41? This is my weekend/track car, I don't put many miles on it at all, it sits most of the time. When I do drive it i'm making pulls to 8,000 RPM. No oil consumption, seals are new. My car seems to like the SynPower 10w30 since I filled it up 80 miles ago.quote:
Last bump...
Hey this sounds like just the thing for my wife's short tripping Aerostar (that is, if I get/have the lead issue resolved).quote:
Originally posted by Motorbike:
Valvoline Synpower 10w-30 UOA with many short trips in an engine with known fuel problems. It did well...
I did use M1 before my engine was rebuilt. I quit using Mobil 1 because my seals went bad 6,000mi down the road, and oil consumption went up. Every VTEC engine i've seen that runs Mobil 1 consumes oil, not sure why.quote:
Originally posted by ekpolk:
Every one of us has his or her own unique combination of particular car-oil-usage factors. Having just done a quick search of the UOA section, I don't see any posted results reflecting a situation similar to yours. It certainly is fun for us to match wits arguing our respective opinions, but for now, that's all they are -- our opinions. If you're motivated to try the Valvoline, then by all means do so. Do a UOA somewhere between 3000 and 5000 miles, and see how it does for your car. If the results are good, then keep on using the stuff. If not, try something else. BTW, for my last four years at Cherry Point (effectively the same climate as yours there at the Swamp), I used M1 5w-30 in a Honda Civic (1988 LX sed). That was way before I even knew you could do a UOA, but that car ultimately ended up lasting over ten years with about 150,000 on the odo, and still had a spotless engine, inside and out, and I never saw a hint of smoke from the tailpipe. I'm still not sure why I traded it in. . . Anyway, if the Valvoline does not work out well, try M1 next.
Engine had 6k on it when valve seals went, they may have been old when rebuilt, but mobil 1 triggered the leak. I've seen many B series VTEC engines consume M1, not just mine. Thats why I went over to SynPower.quote:
What was the engine's history at the time you had a problem? A friend of mine uses M1 5w-30 in his wife's Odyssey, which of course, has the 3.5L VTEC V-6. He has not observed any difficulty on M1. As you can see if you nose around this site long enough, the Mobil-1 30 wt grades all tend toward the thin end of the 30 wt spec. If the engine is older or otherwise damaged, perhaps a thicker 30 (like GC for example) or even a 40 would work better.
Semper Fi.
