Valvoline Synpower 10w50 - 7365km's.
200ml added over fill (Larger K&N filter used)
1st Test (ulx-10W50) 2nd Test (ulx-20W50) 3rd Test(Synpower 10w50)
(10,500ks on oil) (5000ks on oil - 200,ooo interval)(7365km on oil 219665 interval)
Fe 17 - 8 -12
Cr 1 - 1 -1
Pb 6 - 2 -2
Sn 2 - 1 -1
Cu 25 - 16 -23
Na 4 - 10 -4
Mo 658 - 689 -7
Si 35 - 25 -20
Al 14 - 21 -2
Ca 1574 - 1587 -2004
Mg 20 - 28 -15
Zn 788 - 807 -888
P 1625 - 2136 -1067
B 1 - 0 -41
Cd 0 - 0 -0
Ni 3 - 2 -0
Mn 0 - 0 -0
Ag 0 - 0 -0
Ti 0 - 0 -0
V 0 - 0 0
K 51 - 13 -9
Water 0.1 - 0.1 -0.1
Soot 1 - 4 - -32
Sulphur 52 - 32 -0
Oxidation 22 - 11 -14
Nitration 36 - 33 -22
V40 117 - 153 -122
PQ Index 5.0 - 6.0 -3.0
Recommendation of B - Monitor Compartment
"More samples needed to develope trend. Copper and Silicon results are Slightly high for hrs/km on the oil. May eb residual contamination from previous oil. Should settle after three or four oil changes. investigate and Evaluate compartment condition. We will monitor activity over the next few samples. InfraRed Analysis appears acceptable for Hrs/Kms. Continue Sampling at recommended interval"(William Adams-Caterpillar)
For the [censored] of me cannot track the silicon leak, unless certainly gaskets playing up. Certainly better than the ULX-110 used previously.
Fe 17 - 8 -12
Cr 1 - 1 -1
Pb 6 - 2 -2
Sn 2 - 1 -1
Cu 25 - 16 -23
Na 4 - 10 -4
Mo 658 - 689 -7
Si 35 - 25 -20
Al 14 - 21 -2
Mg 20 - 28 -15
Zn 788 - 807 -888
P 1625 - 2136 -1067
B 1 - 0 -41
Cd 0 - 0 -0
Ni 3 - 2 -0
Mn 0 - 0 -0
Ag 0 - 0 -0
Ti 0 - 0 -0
V 0 - 0 0
K 51 - 13 -9
Soot 1 - 4 - -32
Sulphur 52 - 32 -0
V40 117 - 153 -122
