Valvoline Syn 5w20, '14 Kia Soul 1.6L GDI, 7,428mi
Holly Springs, NC USA
Code:
Make/Model Kia 1.6L GDI
Oil Type&Grade Valvoline Synthetic 5w/20 (Dexos1 Generation 2)
MI/HR on Oil 7,428
MI/HR on Unit 75,039
Sample Date 6/15/2018
Make Up Oil Add 0 qt
Element in PPM Sample Universal Avg
Aluminum 5 4
Chromium 1 0
Iron 24 20
Copper 1 8
Lead 0 0
Tin 0 0
Molybdenum 54 73
Nickel 0 0
Titanium 28 6
Potassium 2 2
Boron 47 37
Silicon 21 14
Sodium 95 54
Calcium 1229 1983
Magnesium 663 85
Phosphorous 674 643
Zinc 728 736
Barium 0 0
Properties Sample Should Be
SUS Viscosity @210°F 53.1 46-59
cSt Viscosity @100°C 8.21 6.0-10.2
Flashpoint in °F *370* >385
Fuel % 0.8 0.8
Antifreeze % 0.0 0.0
Water % 0.0 0.0
Insolubles % 0.4
TBN 2.2 >1.0
COMMENTS
Universal averages for Kia's 1.6L GDI engine are shown in the far right column, based on an average
oil change of ~5,800 miles of oil use. You're getting a little more metal than average, but you're also running
a longer-than-average oil change, so that's not a problem. In fact, on a per-mile basis, metals are right on
target, as the wear-rates (ppm/mile) are pretty similar to averages. We found some fuel at 0.8%, but that's
not a problem, and there are no other contaminants we can see. The TBN is still good at 2.2, so 7,500 miles
(or even longer!) is fine.
Well the oil held it's viscosity up well. Fuel is a touch high but not that bad at all. The oil did good.
Amen Captain
Originally Posted By: PimTac
Good report. Is it possible the op ran Synpower before this? That would explain the sodium.
Yes, I forgot to mention that. Previous run was old formula Valvoline SynPower, and before that Valvoline Conventional... so the elevated sodium levels aren't surprising.
Originally Posted By: wemay
Direct Injection:7,400mi oci and stayed in grade. Actually, excellent.
Good there. Wondering why insolubles were at 0.4. I've seen 0.1 or 0.2. Could have something to do with soot agglomeration. I'd switch to a Fram Ultra to try to get that number down next time.
Valvoline is a good choice in oil, no doubt.
