Vehicle:
2006 Scion tC 2.4L 5 speed.
Oil:
Valvoline NextGen 5w30 Conventional.
Oil additives:
None
Gas Additives:
Redline's Fuel System Cleaner @ small maintenance doses.
Make up oil added:
One (1) quart was added during the run @ 1/4th qt intervals along the way.
Engine oil capacity:
4.1qts
Oil filter:
TINY Mobil 1 (much smaller then the OEM filter)
Air filter:
Amsoil EA cone air filter - untouched for probably 20k miles now.
USE: Mostly highway/city @ 60/40. I was redlining and running the car HARD up till the sample / oil change.
The previous oil was VNG in the same grade.
Comments are welcomed.
Code:
OIL Valvoline NextGen 5w30
MILES IN USE 5,139 miles
MILES 107,852
SAMPLE TAKEN 05/10/2013
Make up Oil 1 qt
Universal Average
ALUMINUM 2 3
CHROMIUM 1 1
IRON 17 15
COPPER 1 1
LEAD 1 1
TIN 0 1
MOLYBDENUM 3 87
NICKEL 0 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 4 2
BORON 3 60
SILICON 11 18
SODIUM 220 64
CALCIUM 1627 2608
MAGNESIUM 14 46
PHOSPHORUS 658 742
ZINC 753 830
BARIUM 0 0
Values Should Be*
SUS VIS 210ºF 57.0 56-63
cSt @ 212ºF 9.36 9.1-11.3
FLASHPOINT ºF 400 >365
Fuel %
Antifreeze 0.0 0.0
WATER 0.0
INSOLUBLES 0.2
TBN 1.7 >1.0
TAN 2.7
Oil:
Oil additives:
None
Gas Additives:
Make up oil added:
4.1qts
Oil filter:
Air filter:
Code:
MILES 107,852
Make up Oil 1 qt
Universal Average
ALUMINUM 2 3
CHROMIUM 1 1
IRON 17 15
COPPER 1 1
LEAD 1 1
TIN 0 1
MOLYBDENUM 3 87
NICKEL 0 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 4 2
BORON 3 60
SILICON 11 18
SODIUM 220 64
CALCIUM 1627 2608
MAGNESIUM 14 46
PHOSPHORUS 658 742
ZINC 753 830
BARIUM 0 0
Values Should Be*
Fuel %
Antifreeze 0.0 0.0
WATER 0.0
INSOLUBLES 0.2
TBN 1.7 >1.0
TAN 2.7
