If this change is before the MM is down to 15% or so, keep in mind Honda believes the extra molybdenum in the factory fill aids break-in by preventing hot spots on cylinder walls as they and piston rings conform. Thus Honda's preference that the ff remain in for a full first OCI.
Idemitsu Zepro with Moly is available on Amazon and has molybdenum content similar to what's found in a Honda factory fill. You may want to consider using it for this next OCI, then revert to something available at WalMart.
Honda's 1.5T has a well-deserved reputation for fuel dilution, so paying particular attention to engine break-in seems prudent. Eventually going to a 30-weight probably has merit as well, though there's the whole warranty debate to consider.
