Originally Posted By: gogozy
Originally Posted By: yesthatsteve
I know it's an awful unit on what has otherwise been a great van. That said, Z-1 simply doesn't withstand the increased heat and stress from the 2nd Gen Odyssey, compared to smaller cars. A number of the members at Odyclub.com are getting far more miles out of those units on Maxlife, Redline D4, and Amsoil than they ever did on Z-1.
Why are they using Z1 when DW1 is FULL Synthetic.... Im not sure if MaxLife is FULL Synthetic or a blend or what.
Just use the real stuff.. Even Eric the Car guy who worked at a Honda dealer for nearly 10 years swears that is the only ATF to use with a Honda.... Check him out on You tube.
Honda ATF DW1 is FULLY Synthetic, There was even a picture shown when the first bottles came out at the dealer that clearly shown.
Here look.
sorry these are Canadian market DW-1. the 1L instead 1q, and French give it away. but US version may be synthetic. just saying this picture can not be use to prove US DW1 is synthetic.
Found out DW1 is NOT SYNTHETIC.. Only in CANADA is syntheic
read
Local dealer called tech line..they said PCM in Canada are different and require synthetic ATF. USA dw-1 is not synthetic and they do not recommend running any full or semi synthetic in USA vehicles.
Found this quote also
US definition of "synthetic" if pretty WEAK. A base 3 synthetic oil is just dino oil "modified"..like Mobil one EP used to be (it still may be). The "real" synthetics are Base 4 stock like castrol edge, Amsoil SS...probably many others. So you could be buying a motor oil called "synthetic" that is actually dino based! If you buy a 0w (which I recommend to everyone) I *think* it has to be base 4 as 0w is hard/impossible to attain with dino.
So I do not get it... So if you buy Canada DW1 is syn but if you buy DW1 in the USA its Not even Syn blend??
also
Not sure if this has been discussed here or not but I am curious about the new Honda DW-1 ATF. Based on MSDS, it may not be synthetic (at least for the US market). In fact, the flash point of DW-1 and Z1 is identical. The flash point is always higher for a synthetic oil. The only difference is that the DW-1 has lower viscosity at lower temperature compared to Z1. Both the Mobile 1 & Redline D4 ATF has flash point that is 66 degrees higher than the DW-1 & Z1 ATF.
ATF FLASH POINT
DW-1: 170C
Z1: 170C
Mobile 1: 236C
Redline D4: 236C
AMSoil: 234C
Royal Purple: 216C
