Originally Posted By: yesthatsteve
I know it's an awful unit on what has otherwise been a great van. That said, Z-1 simply doesn't withstand the increased heat and stress from the 2nd Gen Odyssey, compared to smaller cars. A number of the members at Odyclub.com are getting far more miles out of those units on Maxlife, Redline D4, and Amsoil than they ever did on Z-1.
Why are they using Z1 when DW1 is FULL Synthetic.... Im not sure if MaxLife is FULL Synthetic or a blend or what.
Just use the real stuff.. Even Eric the Car guy who worked at a Honda dealer for nearly 10 years swears that is the only ATF to use with a Honda.... Check him out on You tube.
Honda ATF DW1 is FULLY Synthetic, There was even a picture shown when the first bottles came out at the dealer that clearly shown.
Here look.
Maxlife is full synthetic:
http://www.valvoline.com/pdf/maxlife_atf.pdf
Why use Z-1 instead of DW-1? Because the newest 2nd gen Odyssey was over six years old when DW-1 came to market. DW-1 hadn't been developed when my van's transmissions failed the first two times (using Z-1, "the real stuff" according to Honda). DW-1 was brand new when the unit failed the third time, and I don't know whether that rebuild got old stock Z-1 or the new DW-1. I did a Maxlife 3x drain & fill at 30k on the rebuild, do a single D & F every six months, and haven't looked back.
ETCG knows Honda repairs. If I were to DIY the Ody's timing belt at 315k, I'd buy his video. Does he know fluids? Not really. Listen to him talk about oil, or look at the old discussions of it here.
If you're convinced DW-1 will swath your gearbox in soothing goodness and never fail, then use it. Better use only Honda-branded oil in the crankcase, too.
