Nick1994
$100 site donor 2024
Changed the gear oil in the Genesis today with Valvoline FlexFill 75w90 gear oil. There's no going back to regular gear oil bottles EVER. I didn't think it was going to be as good as it was. Not really any room to put a bottle up there, I have the nozzles with the hose that you screw onto the bottle but you can't beat gravity, the bottle needs to be higher up. With these pouches you just push the bottom in and the fluid flies in super fast.
Walmart has them for $12.67. Amsoil does the same thing with the pouches too, I think they were first.
Full Synthetic Gear Oil - Valvoline™ Global
Valvoline™ SynPower™ Full Synthetic Gear Oil is formulated for ultimate protection and performance. A thermally stable, extreme-pressure gear lubricant, it is designed to operate and protect in both high and low extreme-temperature conditions. SynPower Gear Oil is specially recommended for...
www.valvoline.com
