Have been using valvoline 5w30 All weather with FL-400S filter and 3000 mile interval in my 1999 Ford Ranger with 3.0. Now has 130,000 miles and runs as good or better than new, with no oil consumption.
Truck is 4x4 with 5-speed manual, 3.73 gears. Driven on interstate for 90 mile round trip commute. Speeds range from 65 to 90 mph. Gas mileage is around 24 mpg. Starts easy in the cold colorado winter mornings.
I would like to keep this truck till 300,000 miles or more. I see no reason why it might not last that long. Heck, it still has the original brake shoes/pads with plenty left. No problems, just fluid changes, serpentine belt, spark plugs at 115,000 miles and just put the third set of tires on it. Cheap and reliable and still looks like new, inside and out.
I am seeing that the Motorcraft synthetic blend is now selling at Walmart and is even a little cheaper than the standard valvoline.
Thinking of changing to the motorcraft, but with the good results of the valvoline I am wondering if I am wise to do this.
Is the Motorcraft oil really better than the valvoline ???
I know it is less expensive. I know that it is synthetic blend, which sounds better. So I dont need to be told these two things.
But specifically, is there any hard evidence, data or factual reasons that the motorcraft will actually be better for the 3.0 engine than the valvoline ???
