93' civic 172k... valves were checked and were within spec last year when this noise was still present, was told there are no lifters....rocker arms didnt need to be adjusted, cars with this many miles just make valvetrain noise? anything bad going to come of it?
also..
i know this is bad to do, but it makes weird valve noises when you start to go to around 5500 rpms in any gear.... you can hear it real good if you go from first to 5th (stick), where its really bogged down....sounds like valves hitting something....or something, bad timing belt? the timing is set right....maybe the belt skipped a tooth?
when i bought it in 2001 the valve cover gasket was not on right and oil was leaking out... maybe this did something to it, noise has been there since i bought it
also..
