Valvetrain/head pics, 2004 2.2 Ecotec ~130K miles
TN
Here are some pics of my old engine's internals. It lived on SuperTech for a long time, then a few changes of Royal Purple, then Mobil1 0w-30 until the last couple of years when I started using whatever synthetic was on sale at work. Piston tops: Valvetrain: Combustion chambers, note burned valve on #3: [img]https://www.facebook.com/photo.php?fbid=...e=3&theater[/img]
MinamiKotaro
TN
Originally Posted By: babbittd
Hi. The carbon on the piston tops and on the surface (?) of the combustion chambers, was it gummy and tarlike or dry?
Wet on the surface only. When you wipe it with a finger, it comes off like ash. The varnish and ash deposits actually look a LOT worse in these pictures than in real life.
Northern Kentucky
I don't think i have seen an impressive echotech torn down. The OLM with these and dino usually produces some pretty heavy varnish and some sludge. Surely a candidate for full synthetic all the time.
Massachusetts
Thanks!
California
These aren't the sparkly-clean images we've come to expect from synthetics. I see you have a burned valve. Was the engine overheated?
MinamiKotaro
TN
No, never overheated. The only thing I can figure is the valve got burned when my factory coil failed. I can't remember if my pinging problem started at that time or not.
MinamiKotaro
TN
Originally Posted By: The_Eric
Burned valve? Where? I see where the piston kissed the valves when the rod let loose.
One of the exhaust valves on #3. It's the bottom leftmost valve in the last picture.
Iowa
I'm guessing this is the 2.2 out of his grenaded Cavalier- the one that ingested water and later broke a connecting rod.
Iowa
Cavalier? It's an ion, the one in my signature.
Yes, my bad. When I think 2.2, I automatically think Cavalier...
