gathermewool
Site Donor 2025
Any ideas on a more permanent solution? we bought this vac in 2015 and it really sucks. Seriously, it’s awesome.
Anyway, the pivot point of the shaft where it meets the head is retained by a really thin pieces of plastic that wasn‘t even full width the whole way around! As you can guess it snapped and the whole shaft slides right out, with only the power cable left holding the two parts together.
I was able to notch the relatively soft plastic in the front and use zip ties at an angle to retain the brush head to the shaft. It’s been working well, but if that notch wears out I might be screwed.
Thoughts?
Thoughts?
