- Joined
- Jan 16, 2025
- Messages
- 16
Is there any advantage of using thicker oil in an older engine.
That’s my question as wellWhat ya got?
An old 305What ya got?
An old 305
Might quiet things down or help oil consumption issues with a loose or worn out engine .Is there any advantage of using thicker oil in an older engine.
If this engine has the original timing chain and gears you would be best to not go beyond a 10W40 in my opinion. Camshaft sprocket has nylon teeth. They will shear off (old set) when the oil pump has to churn thick oil.An old 305
You got 400k out of a GM product? I never got more than 190k! What year/model is this?Had to go to 0w30 & 5w30 as the rings are worn and with almost 400,000 k, why not? GDI engines see fuel dilution so it will thin it some. Changing oil sooner is better than later
10W40 at 0°F, or at 60°F?If this engine has the original timing chain and gears you would be best to not go beyond a 10W40 in my opinion. Camshaft sprocket has nylon teeth. They will shear off (old set) when the oil pump has to churn thick oil.
Viscosity is determined by 3 factors.
1. Operating oil temp
2. Rod and main bearing clearance
3. The load on those bearings
Unless you've modded the engine significantly, these parameters will not change much, if at all. In a healthy engine, you will likely not wear the bearings enough to warrant an increase in viscosity.
That said, there's no harm in it either. You could run a 5W-40 or 10W-40 in this old 305 that called for 10W-30 and will be just fine. You might lose -0.5% power and fuel economy.
I know a lot of people with these older engines like to use HDMOs like BROtella. I'm not a fan of that in the least. Use an appropriate oil with the foam prevention, oxidation resistance, and ZDDP content the engine needs. Valvoline VR1 synthetic 10W-30 is a good choice. If it's a roller cam or stock flat tappet, a Euro 0W-40 or 5W-40 would work well. Top Shelf options would be Red Line HP 5W-30, Driven LS30 5W-30, Amsoil Premium 10W-30, and HPL Bad Ass 5W-30/40.
It's not the journal bearings that I think off when considering oil viscosity, though with autamatic start/stop a higher viscosity wouldn't hurt every time the engine stops or starts, by lowering the rpm at which hydrdynamic lubrication is achieved, and especially turbo engines tend to wear the top conrod bearing shell which indicates to me the oil film isn't quite thick enough.
But there's pistons vs bore, pistong rings, chains and sprockets (more so in dohc designs than old ohv), cam bearings (halve rpm and smaller diameter, often no replaceable bearing shells and highest lubricated point in the engine receiving oil after startup last) which are aften reduced in length on the bottom limiting the oil supply even more, valve guides (quite hot and not much oil should make it there), oil pumps themselves (see unfiltered oil, or filtered oil that has gone through the engine to be more precise), vacuum pump, turbo bearings.... All of these can codemn an engine over time and the car with it, especially considering if one system needs replacing the rest is likely in terrible shape aswell. It doesn't matter one bit if you intend to replace the car at the end of the loan though.
You can’t honestly believe that there aren’t MANY GM vehicles out there with 400k plus? Because there are quite a few.You got 400k out of a GM product? I never got more than 190k! What year/model is this?
