A bit of background - the previous owner never replaced the coolant in my Grand Marquis, so it was a total disaster when I got the car. Also, when he had the coolant pump replaced at one point, it was refilled with Dexcool.
Anyhow, I've lost count of how many times I've flushed the cooling system using various methods. I always use Motorcraft G-05 at a 50/50 ratio, but it always turns dark orange with a brownish tint to it without fail. I also use Liqui-Moly's radiator cleaner, which I add 2 cans of to the cooling system and let the engine idle for 30 minutes as instructed. I use distilled water to flush and refill as well.
As far as how I flush the system is concerned, I first remove the thermostat and the upper radiator hose. I block the upper radiator orifice with a radiator hose I've attached a radiator cap to, to prevent coolant from spilling out as I flush out the system. Next, I start the engine and keep feeding relatively warm distilled water until it runs clean.
Now I don't know what's turning the coolant brownish orange, but I'm thinking about continuing to flush the system another couple of times. Now the problem with this is distilled water is only available in 1 liter bottles, so I end up filling 3 10 liter containers to flush the system. But this isn't doing my back any good.
I was wondering if I could use regular tap water from a running hose to flush the system and make things easier, but dilute the coolant with distilled water. Or on another note, dilute the coolant with tap water but shorten my coolant replacement intervals. Currently that stands at 25,000 miles or 2 years, but I'm really flushing out the system every 6,000 miles because of the color change! Thanks for any input!
