Originally posted by daemonite:
[QB] MMO in the gasoline...
Someone help me out here. I keep trying to catch someone actually typing out what 'MMO' is but it aint happenin'. Society and its abbreviations![]()
Anyway, can someone please tell me what MMO is?
Yep, Penzoil 5W-40 euro formula. A3 right on the back. I got it in the crankcase now. I did just add half a can of SynPower. I tool around at 3500 rpm at 45 mph. When my engine is smooth I can tell. I can tell the difference with an oil change.quote:
5W-40 viscosity that meets the European ACEA A3
You might want to read this!!! Bob experiments with oil additivesquote:
Originally posted by jdmboy:
My motor is pretty high strung turbo motor. It gets alot of rpms and agressive use. I am running Penz 40weight euro currently. Are there any additived that can be used in the oil. You know like Slick 50?I am kidding, but really, are there any additives to help or is the oil all I need.![]()
I am sitting here with a bottle of MMO. I don't know man..... I don't trust I know a guy who knew a guy who use it in his 65 Impala and swore by it kind of proof.
These two dimensions are the ones I am after.
Antiwear/Extreme Pressure Agents: These agents bond to metal surfaces to create a strong lubricant film between moving metal parts. This film can withstand extreme heat and mechanical pressure to keep metal parts separated, protecting them from scoring and seizing.
Friction Modifiers: In effect, they make oil more slippery by reducing the friction between moving parts. This both reduces wear and improves fuel efficiency
Thanks
