Hey all I’ll be changing the shocks for my 14 rdx and am going with KYB shocks for the rear.
Kyb 554406
I was originally going to buy NEW oem bump stops from Acura until I realized that the kyb comes with new ones
Am I presumably supposed to use the KYB ones and discard the old oem ones? Or is it good reason to get new Acura bump stops and use them rather then the kyb one
Unless I’m mistaken, I assume you can only pick one bump stop and I also assume the Acura one probably won’t fit the KYB ones
So I guess don’t order new Acura ones and just run the KYB?
Thanks
Kyb 554406
Thanks
