Using AutoRX in 700R4
NY
im considering using autoRX in my suburban- I'd be more than happy to apply the RX and then do a drain, but Not a complete flush.
Is there any extended harm in leaving some AutoRX in the system? I have a supplimental inline transmission filter (uses FL1A filters), that I could change easily.
ifs its necessary, I will of course do it...
but if its not, then I'd just leave some in.
I have used ARX in two Burbs with 700R4's.
Use only maintainance dose do a pan drain and refill within 15k.
ARX may have other directions for you but this worked for me.
Thats what I was thinking. The previous owner did yearly pan drops and filters (I still have the receipts). Im thinking a drop, filter, and maintainace dose should be adequate.
just did an arx treatment to a 700r4 in a g20
it was a bit low so i added the 12oz arx and drove it 1000 miles followed by a cooler line exchange and pan drop/filter.fixed the rough 2-1 downshift.
old fluid was real dark but not burnt smelling.
