According to this article it is not a good idea to use a GL-5 fluid in a transmission designed for GL-4
http://www.widman.biz/uploads/Transaxle_oil.pdf
Are there any exceptions? Is there some new technology that makes GL-4 obsolete?
My Fiat's gearbox is spec for a GL-4. The (1998) workshop manual states to use Fiat's own "Tutela ZC75 synth" which at the time was a full synthetic 75w80 GL-4. However if you go to the dealer and buy this oil it is now a GL-5. I believe Fiat changed the spec of the oil from GL-4 to GL-5 at some stage after 1998.
So is it OK to use? My gearbox does have soft metal syncros. Is it possible they have formulated the GL-5 fluid with additives that are not detrimental to soft metal syncros?
