quote:Regardless with 10lbs of pressure hot with a 40wt ....... good luck with a much thinner oil
Originally posted by kickster: I have owned many VW and they all run about same oil pressure. The engine is in great shape, no oil burning, no engine noise.
quote:I once again agree with Motorbike...with such pressure running a forty-weight, I see absolutely no reason to use something thinner. Have you considered M1 15w-50?
Originally posted by Motorbike: Regardless with 10lbs of pressure hot with a 40wt ....... good luck with a much thinner oil
quote:Too low for my comfort still . Could be a worn oil pump from running thick oils in a cold climate all it's life . Might be bearings or both but too much to cover on a forum as it could yet be " one " more problem that's oil pump related . I'd nix the 0w-30 idea based on my opinion of what is wrong with the motor .
Originally posted by kickster: the light was due to bad oil pressure sender. I have about 10 to 16 PSI pressure at 700 rpm idle and 25 to 30 PSI at 2500 rpm. (oil temp at 100C.)
