Used oil shelf life (for testing)?
Canada
If I saved a sample of my used oil for later testing:
1. would the oil's chemistry change from sitting?
2. if yes to #1, how long could it sit?
3. how much of a sample is needed for testing?
Thanks
Have it analyzed early if you can. The older the sample the greater the uncertainties. Results don't age.
That said, keep it in the dark and keep the temperature cool & stable. Using a non-leachable container would also help. I have a couple samples in canning jars waiting for $8 kits.
David
I draw 6 oz samples on the average. Some labs like six, some four. I believe 4 oz. is the minimum.
Maybe Terry Dyson has a preference.
Your highest risk from sitting is evaporation of fuel contamination, so it is a good idea to send relatively soon after draining. I send samples to my Lab on the 1st of the month and somewhere in the middle of the month. Anything that gets to me on the 2nd waits a couple of weeks.
For Engine tests I always send about 100 ml. and keep another 100ml as a counter-sample in case anything happens.
