Use of Fuel Supply Hose (1/4" ID) in Cooling System Service
Vancouver, BC Canada
I have a vehicle where a system associated with the PCV valve is heated (heat-traced?) by a slipstream of coolant taken from the upstream heater core nozzle, and returned to the downstream heater core nozzle. The hose size is 1/4". I went to an industrial hose supplier, telling them that Gates makes 1/4" sized heater hose; they said they don't have that product. I said, what else is rated for say 240°F, 20psi, water-ethylene glycol mix. They sold me fuel hose.
Attached graphics, 2.
What do folks think of this swap?
The pressure and temperature of the coolant should be able to be handled by a fuel line. I see no chemical issues with a fuel hose carrying coolant while a coolant hose may degrade carrying fuel. Personally, I think you will be OK with this.
I have heard of cooling the EGR gas but this is the first I have heard of modifying the temperature of the PCV gas.
What make, model, engine, and year of vehicle does that?
1994 Mercury Topaz, 2.3 L4, 5 MT.
I am reassembling it, dealing with the abuse of improperly storing it, and the top half of the intake manifold has yet to go on - but if memory serves the PCV valve outlet from the valve cover ties directly in to the upper section of the intake manifold. There is a small heat exchanger that the PCV flow flows thru right at the point of manifold tie in. Said exchanger fed with hot coolant, with cooler coolant leaving.
This is a Cdn car; they may have suffererd PCV freeze-up at some point along the car's design trajectory?
