Upsizing the tires on my Mazdaspeed 3
Back in Arizona. Finally
OK, my Mazdaspeed 3 is equipped with 215*45*18 Bridgestone Potenza tires.
I just replaed them with Pirelli PZero Nero Rossos. So far my impression is that Pirelli tires s uck - they flat spot overnite and they balanced out, at best, just so-so.
I went with these tires because there isn't a lot of choices in this size at tirerack.com.
They only positive thing about the Rosso's is that they have a unidirectionl tread and can be crossed at rotation time.
I would really like to put Michelin Pilot Sport A/S on the car next round - whoops!, those tires don't come in the stock size.
My question is this...can I get to those Michelin tires in an upszed tire, and what size should I go to?
Anybody here have a MS3 that they have non oem size tires on the factory rims?
Cheers and thanks for any input!!
I think they're 9 inch rims. And I agree with you Johnny, the Bridgestones were great, but I like high performance all season tires because they have a higher treadwear rating and there are times when they come in handy. I'll have to check the rim width on tirerack and get back to you. Open to any suggestions....
have you tried any mazdaspeed forums for ideas? I would do comparisons on tire diameter also, do a search for 'miata tire calculator' to get a good one. OTTOMH, I'd say a 205/50 (if there is such a thing) would fit.
I doubt it. The recommended rim width for 215/45/18 tires is from 7 to 8 inches, so your rims must be somewhere in that range.
So, you could run 225/45/18 tires, which have a recommended rim width range from 7 to 8.5 inches. Tire selection is much better in this size, but you need to check if there aren't going to be any clearance issues with that slightly larger size.
Thanks Quattro! I forget where I got the idea that my rims were 9 inches - maybe it was on the plus size tire calculator on 1010tires.com, but at any rate you are probably right.
mpvue - I went to mazdas247 to see what those guys are doing and kinda got a mixed bag - no real solid evidence that a plus sized tire will go down without some sort of **it - it's either "I had to roll my fenders" or "the car is all over the place with the new oversized tires". Brother!!
It's a by gum shame too, since I have the Michelin Pilot Sports A/S on the 330ci and they are GREAT on that car. We just had a light winter storm here in Houston featuring snow and everything and the Bimmer did just fine. And one gives up very little for having that A/S tacked onto the PS name.
Maybe with a little bit of luck the tire selection in this size will get better in the next year or two.
Cheers all!
Your owners manual should give you rim size. For upsizing you use the half split rule. 225/40 18 is the next upsize followed by 235/35 18. Up the width drop the aspect ratio.
That doesn't always work out that way. For example, diameter difference between 215/45/18 and 225/45/18 is only 1.4% while between 215/45/18 and 225/40/18 it's 2.1%. But I agree that the 225/40/18 is less likely to cause fitment issues since it is smaller than OEM. It is also a very popular size.
