This is just an updated report, with the correct mileage on it now. Ignore the other one.
Oil: 5 quarts of Pennzoil Platinum 5w30 & .6 quart of Mobil 1 0w-30
Total Miles: 11,000
Miles on Oil: 2,700
Car: 09 Mazdaspeed 3 w/ mods: Cobb Short Ram Intake & Turbo Inlet Pipe, High-Pressure Fuel Pump Internals, Street Unit's Test (mid/race) Pipe, Step colder Denso Iridium Plugs w/ upgraded coil pack springs, CP-e Rear Motor Mount (60 dur),
Driven: Sometimes very hard. Maybe 10-15 full, hard pulls running through all the gears to redline. 60% highway 40% city. I have a daily commute of 20 miles all highway to work, and 20 miles back Monday through Friday. I did a few car warmups as temps have been near or below freezing this entire oil use.
Info: The reason for the short change of only 2,700 miles is b/c I've recently felt the car was "off" and not running near its potential after doing some of the upgrades. Worse than it was running before them. I don't know if this was just the cold weather or what but I was a little worried and wanted to make sure all was well. Also, as I didn't have a used oil analysis on it yet, and I wanted to quickly get a baseline down and start moving the miles up. I will be running my current fill (German Castrol) for 4,200 miles and then used oil analysis'ing.
The high Manganese is from lots of fuel additives. MMO was in every tank to help break in the new fuel pump internals, and I used octane booster in almost every tank. Also used a fuel injector cleaner in about half the tanks.
Oil was caught after a 30 minute highway drive, caught midstream.
It was a Fram cartridge filter. They actually make a nice filter for my car. Looks just like the OEM's. I put a Pure 1 cartridge filter in it currently, and am NOT happy with it. By comparison it looked cheap and shoddy.
Total Miles: 11,000
Miles on Oil: 2,700
