UOA from Russia: Honda CRV 2.4L - Liqui Moly 5W-40
Russia
Hi guys! This is my first post here. Moscow city, terrible traffic. friend's car - Honda CRV 2,4L gasoline. Oil - LiquiMoly TOP TECH 4100 5W-40 - typical european formula.
Code:
Miles on Oil: 7458
Miles on Unit:26103
Sample Date: 06/30/2011
Make up oil: 0.2 L
Aluminum     6
Chromium     1
Iron         42
Copper       8
Lead         0
Tin          0
Molybdenum   69
Nickel       0
Manganese    1
Silver       0
Titanium     0
Potassium    1
Boron        71
Silicon      28
Sodium       5
Calcium      2240
Magnesium    9
Phosphorus   831
Zinc         990
Barium       0
cSt Viscosity @ 40oC     80.4
cST Viscosity @ 100oC    13.5
Flashpoint,              n/a
Fuel                     2.7%
TBN                      2.46
TAN                      5.76
Oxidation                25
Nitration                38
avss1
Russia
Originally Posted By: zyxelenator
welcome Analiz kakoy laboratorii? Zheleza mnogovato, a tak norm.
Polaris laboratory.
MN
welcome I work with a guy from Russia! Wow - that's a lot of Iron. There's some wear going on in that engine. Those are not the best driving conditions at all and I would not extend the oil changes out too high. Have a great day over there! smile
avss1
Russia
agree. I think that silicon is a reason
MN
Yes, change the air filter and check the air flow system for leaks. thumbsup
avss1
Russia
ha! oil change was done on 9320 miles (Official Honda service - 15 000 km = 9320 miles OCI) frown then there were 2 tests of the new oil - virgin and after 217 miles (actually a fresh oil with some part of previous LM). Important point that TBN (ASTM D-4739) decreased from 9.74 to 7.18 after 200 miles! Acid components as well as Iron and Silicon come from previous oil.
Code:
            LiquiMoly     LUKOIL LUXE Synthetic 5W-40
                           VOA           UOA
Miles on Oil: 7458          0            217
Miles on Unit:26103         --         26300
Sample Date: 06/30/2011     --         08/22/2011
Make up oil: 0.2 L          --           0
Aluminum     6              0            0
Chromium     1              0            0
Iron         42             0            8
Copper       8              0            1
Lead         0              0            0
Tin          0              0            0
Molybdenum   69             0            11
Nickel       0              0            0
Manganese    1              0            0
Silver       0              0            0
Titanium     0              0            0
Potassium    1              0            0
Boron        71             49           45
Silicon      28             4            9
Sodium       5              1            2
Calcium      2240           2880         n/a
Magnesium    9              12           n/a
Phosphorus   831            918          n/a
Zinc         990            1017         n/a
Barium       0
cSt Visc @ 40oC    80.4     77.7         74.7
cST Visc @ 100oC   13.5     13.61        13.0
Flashpoint,        n/a      n/a          n/a
Fuel               2.7%     ---          1.3%
TBN                2.46     9.74         7.18 !!!!!
TAN                5.76     2.61         n/a
Oxidation          25       ---
Nitration          38       ---
ps. sorry for my english
Florida
Daaa, i'm starting to think that the oil might be a little too thick for this engine. In the US, this engine would spec 5w20. If the oil is too thick, it's taking much longer to get to where it needs to be, so engine wear increases. You also mention that the oil was changed @ 9,300 miles but the report shows that you sampled @ 7,450 miles... if you added another 2,000 miles after then sample, i'm sure EVEN MORE engine wear was done during that time.
WatUpDoc
I too wonder why 5w-40 is being used. Isn't Moscow a colder climate, like northern US?
avss1
Russia
Originally Posted By: ltslimjim
[quote=Artem] I too wonder why 5w-40 is being used. Isn't Moscow a colder climate, like northern US?
Moscow climate - -10-20oC in Winter (sometimes -25-30), +25+30oC - in Summer (sometimes +35). 5W-40 is the 2nd popular grade in Rissia after 10W-40. 5W-20 i think less than 0,5% of total volume. our drivers think that use of low viscosity oils like 5W-20 lead to engine wear.
WatUpDoc
avss1
Russia
^I'd suggest a compromise. Find a 0w-30 full synthetic; Liqui Moly makes a very good 0w-30
thanks grin as i mentioned this is not my car. for me LM is too "marketing" oil. i prefer another brands - mobil/castrol/lukoil
MA
i would have to agree that the 5w-40 could be too thick. what does honda recommend? i would be surprised if it was 5w-40. uoa's of 5w-20, 0w-20 in the honda 2.4 show minimal wear. this particular engine is "easy" on oil. have your friend check the owner's manual.
OVERKILL
$100 Site Donor 2021
Ontario, Canada
My experience of 5w40 in a Canadian winter (which is just as bad) in an engine that also spec's 5w20 didn't yield results that looked anything like this.
avss1
Russia
5w-20 does not exist in Honda manual for Russia (p.410-411) wink , sorry for russian version http://www.hondaonline.ru/docs/CR-V_guide.pdf
OVERKILL
Ontario, Canada
Hey, I'm not telling you to run 5w20, LOL. I'm saying there really shouldn't be much of a difference in the UOA results. I used both Mobil 1 5w20 and Delvac 1 5w40 and the difference between the two in terms of UOA results were negligible.
