Here is my Used oil Analysis 11,500 miles on Rotella T syn 5-40 62K on the truck with the FS2500 bypass filter. The other UOAs in the pic where using Delo 400 15-40 not much of a change going to run RTS until 14K and do another UOA. I'm happy to see the Silicon down some I'm sure having 62K on the air filter makes it filter a little better. This is a mix of CI-4 and CJ-4 RTS.
Shell Rotella T 5W/40 (Syn) 1qt make up oil 11,500 Miles on the oil FS 2500 filter
Congratulations! Your 2006 GMC has scored its first "hat-trick" of perfect reports. This was your second longest oil run since testing began and all of the wear metals in this blend of two different 5W/40 oils matched up well to averages for the 6.6L Duramax. Iron at 20 ppm is due to the longer oil run since iron will track with miles of oil use. Now that your diesel is well beyond the break-in stage you should be able to extend oil use up to ~14,000 miles. The TBN was strong at 7.6 so this type oil had plenty of life left in it. Try 13,000-14,000 miles next time.
ALUMINUM 3
CHROMIUM 1
IRON 20
COPPER 5
LEAD 2
TIN 4
MOLYBDENUM 17
NICKEL 0
MANGANESE 0 0
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 40
SILICON 12
SODIUM 1
CALCIUM 3810
MAGNESIUM 60
PHOSPHORUS 1279
ZINC 1657
BARIUM 0
cSt Viscosity @ 100°C 74.8
SUS Viscosity @ 210°F 14.21
Flashpoint in °F 440
Fuel % Antifreeze % 0.0
Water % 0.0
Insolubles % 0.3
TBN 7.6
ALUMINUM 3
CHROMIUM 1
IRON 20
COPPER 5
LEAD 2
TIN 4
MOLYBDENUM 17
NICKEL 0
MANGANESE 0 0
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 40
SILICON 12
SODIUM 1
CALCIUM 3810
MAGNESIUM 60
PHOSPHORUS 1279
ZINC 1657
BARIUM 0
Water % 0.0
Insolubles % 0.3
TBN 7.6
