- Joined
- Sep 28, 2002
- Messages
- 39,799
It's not so scary. The ADD is there as a buffer. It's not like if you're 1mm lower the engine seizes. When it's below the readable area on the stick is when you're in uncharted territory. Do it ..or don't do it. If I see my wife's sump is low (last time it used a quart it was over a 9k span) ..I may let it go for a day or two before adding it since it's usually discovered just before she's leaving ..and we don't cross paths for a day or two.
I don't know how much faster your oil will heat up. If you want to heat up your oil faster, get a heat exchanger. It's assured to warm up the oil in the shortest amount of time ..and they're made for a large variety of engines ..or can be adapted to them.
I will readily admit that this is a "counter" BITOG act.
