gathermewool
Site Donor 2023
I feel like we get one of these threads every month or so.
I say, ’so freaking what!’
An inch over is nothing. Rest easy, OP.
Just leave it now. As others have posted don't overthink it. You're good to go.I’m on the road so I can’t go back to the same shop. I crawled under and got some out. Should have drained more but what do you guys think now?
Sorry the photo isn’t the best but now it’s another 1 centimetre past full. The photo isn’t good. It’s still slightly overfilled but before it was literately 1 inch overfilled on the dipstick
This is the least of his problems with that vehicle.If I recall correctly his Hummer goes through oil like no tomorrow.
since he has already drained it his job is to keep check the stick and adding along the way.
In my truck with a 6.0 Vortec GM LQ4; the lube place seems like they overfilled by 1 inch on my dipstick. I checked many times on various diff surfaces once I got home. It originally takes 6 quarts for the engine but idk how much they put in.
I didn't care to check cuz I’ve never had this problem before.
It’s basically an inch above the hash marks on the dipstick.
so do I drain? Or what do I look for?
thx
We golden thanks so much. I totally don’t mind when it’s like a centimeter or half a centimeter. But this place literally did 1+ inch so I was like wow.
Now it’s at a good spot![]()
The oil inside the oil filter and the oil galleries up to the top of the intake manifold will drain out, but no more. Yes, you have to have a pan and yes it makes a mess, ( unless you buy an Oil Udder). Oil Udder guys, you owe me on.
Keep in mind, your dipstick enters the oil pan at an angle so one inch on the dipstick is less than one inch of oil level. I would not worry about it.
If it's ok to over fill then why don't thy have crosshatch marks above the full line.
