0 07titan Joined Aug 21, 2015 Messages 130 Location USA Mar 28, 2019 #1 I have a 96 travel trailer, (fleetwood prowler), had to replace a bad line on the pump for the slide out, manual said's use type A ATF. No longer available for years. Mercon or dextron good enough?
H HangFire Joined Aug 21, 2013 Messages 4,466 Location Central Maryland Mar 28, 2019 #2 Is this a hydraulic application, not an automatic transmission? I think the usual recommendation of Dexron III/Mercon (not later for either) would apply. https://www.tractorsupply.com/tsc/product/traveller-atf-dexron-iii-mercon-transmission-fluid-2-gal Fleetwood is still around, I suggest you give them a call to verify.
dave1251 Joined Jul 15, 2005 Messages 13,189 Location Maricopa Arizona Mar 28, 2019 #3 DEXRON VI is the modern spec.
Rand Joined Aug 20, 2003 Messages 21,333 Location NE,Ohio Mar 28, 2019 #4 Originally Posted by dave1251 DEXRON VI is the modern spec. but thinner. if its for hydraulic use in a slide out on a trailer.. I'd want dex III /merc vs the newer thinner dex VI Though I'd imagine its not that picky and pretty much any of them would work ok.
S slacktide_bitog Joined Mar 20, 2008 Messages 16,024 Location USA Mar 28, 2019 #5 Plenty of Type A is available at shady neighborhood dollar stores, and possibly Dollar General too No really though, you can use Dexron with no problem
MolaKule Staff member Joined Jun 5, 2002 Messages 23,974 Location Iowegia - USA Mar 28, 2019 #6 If this is for a hydraulic application try Type F.
0 07titan Thread starter Joined Aug 21, 2015 Messages 130 Location USA Mar 29, 2019 #7 Thanks to all.
K ka9mnx Joined May 21, 2018 Messages 3,780 Location South Carolina Mar 29, 2019 #8 Originally Posted by MolaKule If this is for a hydraulic application try Type F. What he said. Any cheap ATF will work.
