Originally Posted By: earlyre
some of these folks are over reacting a bit. i get their point about not needing another router per se, BUT, most of the time a repeater/range extender costs more than a second router, and you can configure the second router to act as a range extender/repeater.
that's what i've done.
at this moment, i forget the steps needed in the setup, but it's easily googleable.
Login to the new router. Give it a LAN IP address within your current subnet. So if your current range is a 192.168.1.0/24 you could give it 192.168.1.254 provided that IP is omitted from the DHCP table on the primary router. Disable the DHCP server on the new router. Save your settings. Then connect it up to your network via one of the LAN ports, NOT THE WAN PORT. Then login to it via the new IP address you assigned it and give it the same SSID and passphrase you have on the primary router. You now have turned it into a cheap access point.
