Two planes collide on the tarmac in Atlanta
San Francisco Bay Area
I guess it still happens.
That'll buff right out.
someone is getting fired. two planes should never cross in that situation. there should be a departing and an arriving taxiway.
Yikes. Is that repairable?
Like Astro said, it's probably not worth it. And Bombardier is no longer in the commercial aircraft business so there's no way to directly replace this with a new jet. I mean - what business are they in now after selling off everything - commercial aircraft, snowmobiles, rail equipment, etc.
Not economically - it’s cheaper to get a new airplane.
So do pilots have individual insurance like a doctor? Or is this all on the airline at fault? How does that work? Is there like a national database for infractions of a pilot?
I wonder if the pilot of the smaller jet chose to retract the gear on the ground to reduce the chance of passenger injuries during the emergency evac? Probably so, in a way that would be a very wise move, but also it puts the nail in the coffin of that airframe. Replace tail and fix damage, maybe economically feasible. But add the cost of all that is required to make that airframe safe again after setting it down on the wings and body, it's scrap. It might have one engine and avionics worth salvaging, not much else as far as I can think of.
I wonder if the pilot of the smaller jet chose to retract the gear on the ground to reduce the chance of passenger injuries during the emergency evac? Probably so, in a way that would be a very wise move, but also it puts the nail in thethe cofinto of that airframe. Replace tail and fix damage, maybe economically feasible. But add cost all that is required to make that airframe safe again after setting it down on the wings and body, it's scrap. It might have one engine and avionics worth salvaging, not much else as far as I can think of.
Can you even do that?
I think the pic you're referring to is just the angle, there is a hill there. From behind the aircraft is still on its wheels.
