![[I dont know]](/forums/graemlins/dunno.gif)
quote:That's exactly what I do if car sat for some time or I didn't used the AC for a while. Both are motors but I don't see how an AC may ruin its much bigger brother. Even if it locks up big brother could chirp the belt into the fumes with smooth idle. On a '75 Olds. manual there are advised seasonal settings for the climatization. So "on" all the time is what the AC "was" designed for.
Originally posted by motorguy222: Isnt a compressor basically a small motor? If so,wouldnt it be better to start it at low RPM's?
quote:I am saying that since most engines start out at a lower RPM,would it not be good to do the same with a compressor instead of turning it on at 50 miles an hour. No,the compressor isnt going to harm the engine,I was not stating such. I am saying that since a compressor is basically a small motor,would it not be best to turn it on at low RPM just as any other motor?
Originally posted by ikeepmychevytoo: [QUOTE] Both are motors but I don't see how an AC may ruin its much bigger brother. Even if it locks up big brother could chirp the belt into the fumes with smooth idle. On a '75 Olds. manual there are advised seasonal settings for the climatization. So "on" all the time is what the AC "was" designed for.
quote:How very right you are! And I, for one, aren't going to sweat just to save a little wear and tear on the compressor. In my vehicles, the A/C is usually already on when I start them, except during winter.
Originally posted by kenw: "I've heard a theory that turning on your AC at higher rpms shortens your compressor's lifespan. " that would be tough to determine since your ac compressor cycles on and off constantly at almost any speed.
quote:Is there any possibility that the oil in the system migrates out of the compressor as it sits idle? GM's Techlink website mentions this here but apparently it's only a concern for compressors that haven't broken-in yet.
Originally posted by kenw: that would be tough to determine since your ac compressor cycles on and off constantly at almost any speed.
quote:Exactly. Especially during the winter. I prefer to have the compressor start the first time when the engine is at a lower rpm and had time to warm up a bit or when I get out of the garage (temp above freezing), then to start the compressor on a cold -20 morning, at higher rpm with very cold oil in it. During the summer, I start the AC as soon as I get out of the garage. It's cool down there and the AC doesn't even struggle in its lowest fan speed, even on hot and sunny days. One more thing. I have learned to turn off the AC a block or 2 before my destination to let go of all the water from the condensation. If not, I get a spill on my garage floor or water could remain in the system and cause odors or blockage later on.
Originally posted by brianl703: I was thinking about the case where the compressor has been "off" for a long period of time (hours or days), and whether oil migration over this time would be a reason why starting it at idle would be easier on the compressor.
