Snowflaque - If you are in warranty still (bear in mind people his car is 4 years old now), and you want to maintain the warranty, then change it every 3750 miles and keep ridiculous maintenance records.
Otherwise, I disagree with what others have said.
Globally, this engine retains a 7500 mile oil change interval recommended by Subaru. It is only in North America where this interval has been shortened.
What I would recommend you do is pick an interval and oil you are comfortable with (5000 with M1 5w30 is fine, better oils are available though) and make sure you, or a qualified mechanic, removes and inspects your banjo bolt.
There is a bolt which allows oil flow from the turbo feed line to the turbo; in the middle of this bolt is a small screen filter. There is some strong evidence which suggests that early turbo failure on these cars is a result of that banjo bolt filter becoming clogged, choking off oil to the turbo. This is because it's not a maintenance item and is never checked, even though it IS a filter.
Have that checked. Some people remove the filter altogether, some people clean it with solvents or fresh oil, some people replace the banjo bolt with a new bolt and filter component.
Thats my recommendation :)
Joe
