I think the place where the oil coking tends to take place is in the turbo bearings, not in the oil lines. It's a cumulative thing. Each time it happens, there is residue (coking - burned oil) left behind. Eventually it will destroy the ability of the bearings to do their job and the turbo impeller shaft will seize up.
I had a 1986 Saab 9000 Turbo which surprisingly wasn't water cooled. I know the old Porsche Turbos weren't water cooled either. They tended not to have a real long lifespan. But these days I think all turbos are water cooled. This makes a huge difference, but I still think that there is a need to cool the turbo down after a hard run before shutting down. In my opinion, the convection action in the WRX isn't enough to completely prevent coking if you continually shut down immediately after driving really hard.
The old Audi S4 engine was really bullet proof and way over engineered.
Nodular cast iron block (stronger than the normal block material). All forged internals. Sodium filled exhaust valves. Oil jets that cooled the underside of the pistons. A seperate oil circuit to feed the turbo bearings. A secondary electric water pump that continued to circulate water through the turbo housing after shut down, until the temps were safely low enough. And guess what...The owners manual still mentioned that you should drive gently or idle briefly before shutting down after driving extremely hard. I can't remember the exact wording, but it was there. Audi really did (and still does I think) want their vehicles to last a long time as is evidenced by their effort at rustproofing. They're second to none in that area, along with Porshe and VW.
It always disappoints me when I see how car manufacturers cut corners with their designs to keep costs down.
Having said all that, Subaru seems to be one of the better manufacturers at being more engineering driven than accountant driven and their cars seem to hold up well over the long run.
