I had an 06. Can’t see the cam through the fill, it’s on a snout. Two 10mm nuts IIRC and the snout comes off, but there may be a baffle beneath that. There’s a plate up under the inside of the thick, solid Al valve cover. and yes, on an 06 the ecu runs the starter up to 10 seconds until it starts or times out. Mine never didn’t start, probably the most dependable vehicle I’ve known.
easier, I think you can just pull the TB covers at the top of the cams and see if the belt is still intact.
solid motors, the 4.7. I have a feeling if he tore a tb and crunched some valves, he’d know it.
id be curious if it’s got a code stored, like a cps.
m
m
