My mother asked me if I could change the oil in her 03 Jeep with the 4.0L I-6. The vehicle was bought used with 33,000 miles on it. This is the first oil change it has seen since purchase in Oct. of this year.
Her and my father left it up to me to pick up the best oil for the best value, after finally convincing them that Valvoline isn't all that great of an oil and that there are much better oils available for a cheaper price. My father was particularly reluctant to give up his deathgrip on his precious Valvoline that "I've used in every car since the very first one I bought back in...."
I ended up going with the "new" 5w30 TropArtic that meets SM/GF-4 specs and says "synthetic blend" on the label. $1.12/qt at WalMart. Filter was a Purolator.
From doing some searching over the past few days on the forums I ran across info regarding all the ConocoPhilips line of oils stating something to the effect that the base oils in these GF-4 reformulations are something like 50%+ GrpIII and the remainder mostly GrpII with a little GrpI mixed in. Is this correct?
Also is this pretty much the same oil as Motorcraft or is the Motorcraft slightly different in additive package?
Finally, does anyone see a problem with using this oil in that engine? It'll be changed every 3000mi because of all the short trips the vehicle makes.
