I have had a number of tires blow out and not all of them have been road hazards. In one case, a bad alignment job caused the inside edge of a tire to quickly wear through until it blew in the stress of a bend going up Pike's Peak. I once made the mistake of buying some cheapy Jetzon tires. One of them blew after the sidewall cracked.
I am suspicious about a couple of other tires that went bad. They developed a soft spot in the sidewall. Of course, the dealer insisted it was ''road hazard'' and denied warranty.
In one road hazard encounter, the rim bent enough to blow the tire, but the tire survived. Same for about a dozen other people gathered in the gas station a block down the road. The kid was ripping off tires, pounding out rims, remounting the tires as fast as he could. He was charging the 1972 rate of $2 for mounting a tire. Bet he couldn't move the next morning.
