Originally Posted By: 1 FMF
the "false charge" is known as a "surface charge".
A fully charged car battery (valve regulated lead-acid VRLA) is 12.65 volts at 70F or 80F ambient temperature. If it's colder then 100% state of charge will be slightly lower like around 12.62 or 12.60 volts. When you're down around 12.50 to 12.40 volts the battery is near 50% state of charge.
If possible charge the battery overnight or for 6-8 hours at 2amp setting but not higher than 2amp. Then let the battery sit not connected to anything for 8-12 hours to get rid of the surface charge. What you can do is put the battery on charge in the evening then take it off first thing in the morning before leaving the house, then measure the voltage on it that evening which should be > 10 hours later. You are measuring "open-circuit voltage" on the battery, which means voltage across the positive + and negative - terminals with them not connected to anything. You should see around 12.65 volts on a digital multimeter. All batteries self discharge over time, so to know whether you have a bad battery is you have to let it sit a day or two then remeasure open circuit voltage and see how much it dropped. Over a week it should not drop more than around 0.02 volts, as long as the ambient temperature did not change much, you should still be over 12.60 volts. if open circuit voltage dropped significantly then that's a good indication the battery is bad.
I was thinking that it was not really called a "false charge" but something close. I guess I was close enough as you knew what I was talking about.
