Troubleshooting A/C in 2004 Yukon XL
Ohio
2004 Yukon XL does not blow cold air when idling, only when engine is under load. High side is 250psi and low side is 0psi. I installed a new A/C compressor, dryer, and orifice tube about 3 years ago. Could the orifice tube be plugged? What other areas/items should I troubleshoot before opening up the system and replacing the orifice tube?
Low side 0? yeah it's bad. I wonder if your gauge goes below 0 as it likely would show a vacuum if it can. Surprisingly my 341k yukon denali ac is all original minus two schrader valves for maintenance and a low side switch.
I believe it was a 4 seasons compressor, but I will check for certain when I get home. Could it be any other issue besides a bad compressor? It blows ice cold while I’m driving. Yukon isn’t my daily driver, I just use it to tow the boat to the lake or move groups of people when needed.
Did you replace the fan clutch or re use the original? Other than low charge it tells me the compressor isnt creating enough pressure.
The low pressure switch in mere inches away from low side service port on the Accumulator.....It would cut A/C request & not achieve 0 PSI for very long if the system is operating correctly.
Low side at 0psi = No compressing.
How do you figure?
0psi low side and 250psi high side sounds like some compression to me.
I am thinking clogged orifice tube makes sense, although I don't know why the low pressure switch isn't cutting off the compressor. How quickly do the pressures equalize after you shut it off?
Low low-side pressure also sounds like the system could be undercharged.
Disclaimer: I'm not an A/C guy.
On my 05 Yukon XL with dual AC I must rev it up to 1500-2000 to get it to achieve correct readings. I have not replaced anything. Previous owner and me find that it loose a can/yr. Suppose it could be lost in those long hoses.
Like brages, I'm no AC guy. But in my limited experience, when low side and high side equalize pressure, that's when a compressor is suspect. I suspect something further down the line.
How do you figure?
Tons of reasons why it would retain pressure on the high side. Temperature for one.
Freon doesn't magically escape into a 0 pressure environment.
Should be around 25 for low.
You could have a blocked office tube, only way to know is pull it out.
Compressor is loading up the high side, and sucking the low side to 0 because there is not enough flow back to the compressor,
That is bad cause for it to be oiled, it needs that flow.
Extremely low refrigerant, the low side will be low, the high side will be lower than normal, and the compressor will cycle off and on.
NOW question is, with 0 PSI on the low side, WHY is the low pressure switch NOT cutting off the compressor?
That makes no sense!
https://ricksfreeautorepairadvice.com/why-you-should-never-jump-a-low-pressure-switch/
  • Like
Reactions: wtd
It's not the only way to know - the amount of time it takes the system to equalize after the compressor is turned off can indicate if there's too much (or too little!) restriction.
I wonder if there's a problem with the low side gauge reading... tools or technique
You really can't assume his low pressure side should be 25 psi without knowing what his outside ambient temperature is.
